SignUp Now!forget to mention, I beleive the TT chip is a open loop set-up, than what would you do??
Ron
would you do??
Ron
but when you get into it will spike way of the lean side on the WB,
Ron
Still thinking it was the existing plugs I was using were too cold and also causing high EGT's, 1788Deg.'s. Timing on the chip is 25 in 1st and 2nd,
23 in 3rd and 4th, timing could also be to low.
Ron
bsd, you might have something there on the 160 vs 180,190 t-stat, when I think about it my car has always run faster when its hot outside, around a
95-100Deg's or so and that has always really confused me, if I do change stats I'm going to check out those Moto-rad's I beleive they are called, the ones that if they do fail they do so in the open position.
Ron
 I've got to get Eric to re-program the chip and I'll be good.
  I've got to get Eric to re-program the chip and I'll be good.bsd, lots of snow here, so right now I'm replacing the rubber lines on my aux. tranny cooler since they are 12-13 yrs. old. Still not sure on the t-stat yet, after work tonite have to take a look at my clothes dryer, it will not turn back on, always freakin something going wrong to keep us broke, lol.
Ron
 LOL.....
  LOL.....bsd, let me know on the t-stat, I will finish the new tranny line install this
week-end, also going to install a tranny temp gauge I got a while back also.
I always been curios of trans temp after a 1/4 mile blast, keep us posted.
Ron
