SignUp Now!Cooling the intake air/air fuel mixture has a direct effect on the exhaust temps. Do this test and you will know another truth that no one will be able to talk you out of knowing.Im not an engine guru but EGT will NOT give you the cooling effect of the alcohol when introduced into cylinder. EGT is the temperature of post combustion. Im talking about pre-combustion, when the air and fuel is introduced into the cylinder prior to ignition thats when the alcohol can do its job of removing heat.
I thought this was the case. Mechanical Pre turbo is the type of injection that fits the non intercooler application so well. I bring this up because you mentioned the restrictive intercooler effecting turbo efficiency. The very fact that we compress the air,effects efficiency in a negative way.If we cool the air as we compress it,it would be a helpful step towards running without a intercooler. The mechanical set-up is so perfect for pre-turb because you don't need to rely on a pump and electronics. I had nothing but bad experiences with alcohol injection. Both with the pump and electronics. Like you,I prefer shooting alcohol through my injectors,but it would also be nice to cool the intake air.Ive tested water injection, methanol injection, 50/50 water meth, E85 injection, pre turbo water injection, denatured alcohol injection, cabinet rubbing alcohol injection even tried xylitol.
I tried relying on these thing and they let me down big time,so I'm right there with you. I love E85.Cooling the intake charge is the ideal thing to do but when you start relying on so many things and have your tune setup on "hoping" those electronics and that pump and that line etc is all working and always working when you give it WOT worries me. The less things you have the less can go wrong. So with my alcohol based fuel i just check alcohol content and make sure Fuel pressure is there. Done
Of course,110 octane fuel will always allow more boost and spark advance than 91.Car runs 24 deg timing through the peak of its curve, with 91 octane that would never happen.
They are directly related.Trouble is you cant really measure combustion temp, only EGT.
It's alcohol,so it has a cooling effect. Another thing I like about alcohol is,because it dissipates and atomizes better,the bigger injectors that are needed,will still atomize well. With gasoline you have poorer atomization with bigger injectors.All im trying to prove is once the E85 fuel and oxygen is introduced in the cylinder before spark (in my case powerlogger proves it without I/C) the alcohol in the fuel pulls out an extreme amount of heat from the hot intake charge. OR does it cool the charge thru the burning of the alcohol??? Now im confused.
Since you're injecting into the intake port of the head,you would be doing nothing to cool the air in the plenum. However,if you injected water pre-turbo or methanol post turbo,you would be able to record the cooler temps in the plenum and see the corresponding drop in EGTs.If i were to take rdgs of an intake charge say @ plenum then post combustion @ header port with an EGT would that give me an idea of the cooling that happened before the explosion?
I have Noticed that on series 2 3800's- when reading plugs they told me to run colder plugs in the middle which I always didDo you guys notice the middle two cylinders run hotter than the rest? Ive seen it on many v6s.
