SignUp Now!49-blues said:What would be the best bearings to use on a new eagle crank and K1 rods? Im thinking clevite ms-960s and clevites cb 1443p-would do you guys think?
87we410877 said:I have somewhat of the same post in For engine builders. I was told only H series clevite bearings should be used because of the side champfers that the P series bearings do not have.........
Nick Micale said:Even if you use the Clevite bearings on the rods, they must be machined for proper fit.
87we410877 said:Is that with the K1 rods too? And also what does need to be machined?
K1tom said:The factory crank has rolled, undercut fillets while most race cranks have .125" radius fillets for added strength. You need to chamfer the bearings to clear this fillet. If the bearing makes contact with the fillet, it will keep oil from flowing out which in turn keeps new oil from flowing in. This will result in burned bearings.
wbrophy said:Had rod bearings machined the first time, the second time I used a box cutter to chamfer the rod bearings (only needed one side of bearings chamfered with my setup). Looked and worked much better (with more bearing surface left) !!!
PS: The bearings are more even and the best part is that it only cost me some time and I know this sounds crude but the overall results were more even. :smile: And I used King bearings, rod & main.
And that is????wbrophy said:This man may have a point?![]()
