- Jan 30, 2010
Has anyone ever had a problem with the crank snout being to large to fit the Crank gear on properly? I measured the Factory Crank snout and it was 1.370, The Eagle comes in at 1.382, Having a problem getting the crank gear over the snout. The new Crank gear measures 1.376, Hence the problem fitting over the eagle crank. Any Ideas? I was thinking about rolling some emory cloth around teh circumference and checking as i go.
Also, on head studs and getting them to seal in the block on the open holes to the water jacket, I would think that there will be a problem in most cases with leaking even with the sealer on the threads. The reason I think this is that the studs will not be torqued into the block as the head bolts are, thus there will be a little more clearance in a stud application vs. using a head bolt where you are actually loading the bolt and decreasing the clearance in between the actual threads. Is there a reason that you couldnt use some kind of thread locking compound on the thread of the head stud to seal it in better? I am just wondering why you wouldnt be able to do this- Do the studs have a mechanical reason for needing to be torqued in with the little end of an allen wrench? Seems like it would seal better the other way. Also, if you look at some of the chevy sites, it looks like some of the guys are using permatex number # 2 or even the 3M weather strip adhesive (Gorilla snot) < (not sure i agree with this) in the open to water holes, Anyone have any luck with this?
Sorry for all the questions, Just curious to see what all of you have to say.
Thanks.
Thanks.
