Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
Some of you experts can probably answer this. I was thinking . . . Lots of the sending units for pressure readings run off a 5V feed.
I know that the ECM has a good circuit for 5V feed and you can “tap into". There is also one on the PL.
If you use PL for logging
, you may decide to add: oil pressure, fuel pressure, alky pressure, additional IAT.
So the question is: What is the circuit capacity of this ECM 5V feed as in . . . . How many sending units can you really run off this circuit before **** blows up?
