jburnsinnj
- Jan 4, 2006
87 Grand Nat 35K -original EGR valve broke. The three screws holding the diaphram to the base sheared off so I am shopping for a new one. Any suggestions as to the best make available. NAPA carries Echlin and also Delphi brands. Local Buick dealer checked computer and found no originals are in stock nationwide and the part is "discontinued ".
I see that a block off plate is also available however how would installing one effect idle, warm-up or driveability ? What do you do with the vacum lines and the selenoid if you use the block-off ?
Thank's in advance for any help on this
