Well, I wouldn't go with the TEC unit just to be different. That's not why I went with it. Use the system that you trust most to get the job, as you define it, done.I agree the TEC isn't the most drag race friendly ECM out there but it does have some neat features that the others don't. It would be nice to have everything available in one package instead of add-on boxes. My engine "consultant" really believes in the ignition accuracy of the TEC unit being a plus as far as bearing life is concerned.
The way I look at it is this - I'll give it a try and if I absolutely hate it I'll yank it and put a FAST system in it. I don't think I'll ever go to Donnie's extreme but it is a little exciting to go against the grain sometimes. Maybe me and Donnie can actually learn some stuff from each other on the TEC unit - who would've thunk? My new car definitely ain't going to be a cookie cutter so why should the ECM? :biggrin:
The way I see it, an ECM is supposed to do two main things very well. If it does other functions, then that's just frosting on the cake.
First, it must accurately supply fuel. That's not really a difficult job. You simply need to pulse injectors at the correct time for the correct length of time.
Second, it has to supply an ignition system. In my mind, it should supply an ignition system that doesn't need other boxes to enhance the accuracy or the power of the ignition system. This is where the Electromotive ignition systems shine above all others. This is the main reason I find it hard to even think of giving this system up. As far as ignition systems go, there simply isn't anything better on the market.
