Finally got some quality time in on my dad's 87 GN. The car tends to not want to start after it's been warmed up. Here's what I found.
ECM 1227148
Prom ID ACXA
Has Ultrachip V. CTW87.50 (set on stock setting)
Fuel pressure set at 45psi (verified with 2 gauges)
Has an issue with cold start. Doesn't want to stay running without a little help from the go-fast pedal.
All 6 injectors read 12.1-12.2 cold.
Replaced coils and wires.
Tried to adjust TPS and IAC but apparently didn't take. Maybe due to the following:
We had 2 different Snap-On scanners hooked up to verify these results. Both showed the same crazy stuff.
Whenever the fan comes on several of the sensors start reading crazy numbers and jump around. For example, CTS goes from 199F to 30F, TPS goes from .54 to 4.30, MAT goes from 52F to -13F, RPM's goes from 1000 to 4890. They all jump around.
During this time the engine doesn't exhibit anything as being wrong.
We toned out all 3 or 4 grounds on the ECM D connector. For grins we ran a separate ground from the battery to both the chassis and engine. No change in displayed craziness.
With the TPS set at .44 the IAC was at 82 steps. RPM's were at 1000. When I set the TPS and minimum air I had .50v and 500 rpm. As soon as the IAC got reconnected the idle went to 1000 rpm, TPS went to .56 and the IAC steps wouldn't drop below 52.
We were unable to duplicate the hot start issue this time. It did act a little differently though. It had trouble starting but did start whereas before it was acting completely dead.
A couple of other points:
The fuel pump is priming every time.
Injector voltage seems a bit low at 9v.
MAT was at 52F. I would think that should read higher due to heat soak in it's mounting location. The garage was ~50F.
Disconnecting the battery HAS gotten the car to start during the no-start condition in the past.
I think that's everything.
Does this look familiar to anyone? Suggestions? Help?
ECM 1227148
Prom ID ACXA
