rarperformance
It'll go or it'll blow
- Jun 9, 2006
This is what I have: This is a new fresh built motor never started until now. This car was fully restored from frame up. .030 motor girdled, GN1 Iron heads, Scorpion roller rockers, Cal Hartline custom roller cam, GN1 race intake with 72mm TB, 80lbs injectors by Siemens, custom made chip from Turbo Tweak for this application. Running a translator with an LS MAF. I set the fuel pressure to 43lbs. as instructed. started the motor and its burning very rich. turned the fuel pressure down to 23lbs. and its still burning rich. I did hook a Scanmaster to it. The Scanmaster powered on but went off as if the ecm is not sending anything to it. Any suggestion would greatly be appreciated?
