Too many terms being thrown around. I have never heard of a solid core spark plug. Solid TIP spark plugs...yes. Solid core spark plug WIRES...yes. Copper core spark plugs...yes. NGKs description of these plugs is...Copper core with or without resistor. The "R" in the id is resistor. Hope this helps with a little of our confusion. I linked NGK's id chart earlier in this thread...it gives all the info needed. Tapered/flat seat, projected/non projected, hex size, thread, reach, temp, etc.
Read the description of resistor plugs on the spark plugs dot com link earlier and it describes why a street car should not run non-resistor plugs. Yes...TR6's have a resistor.
Rob
Thanks for the info Rob, I was reading about that earlier and finally got up to speed on all of this spark plug technical data. It seems that the theory of the plugs causing my original problem is blown out of the water now. Back to the drawing board...I will have the new head gaskets tomorrow and I will have it back together some time tomorrow or Saturday. My only concern now is if I have the same problem again I don't know what to do since I don't want to run around testing it again and blow another head gasket!
