forgot the proper clearance on the gears but did you make shure they didnt lock up when you bolted on the oil adpt cover? loose cam sensor would make some noise no doubt
yes they turned freely i spun shaft with a drill for priming it.and I know gears did not hit side of case when i put them in cover.
