turboskylark
- Aug 26, 2006
I have a 87 t ,I have a loud engine noise,sounds like it coming from the front of engine,removed belt and started,not coming from accesories,sounds like possibly from the front cover,also removed valve covers and i dont see any bent pushrods,they are all spinning and seem ok,also there is no a/f in oil,I might of spun a bearing or ??Is it possible to lower pan and check bearings without removing engine?? and could it be something common that goes bad in front cover,I am in the process of swapping a 3.8 turbo in a 1972 skylark and I sure dont want to pull another motor.any help would be great. thanks
