engine problems
quickinda6
broken regal
Hello All, New poster and long time lurker, I'm having this problem with my 87 gn. i had a valve cover gasket leak on the pass/side. so i changed it twice. make a long story short when i pulled my exhaust manifold i noticed oil in the exh ports of the head on the 2 and 6 exh ports. so i did a compression test on the pass/side and i came up with all the numbers reading between 125-135. so i removed the rockers and applied air to the cylinders and air is pouring out of the exhaust ports on the heads, i dont know much on the engine it might of been toyed with. its mostly stock and milleage unknown.
Vinny:confused:
Sounds like you need to take the head off and find out if there's a problem, but if you've got air escaping you probibly do.
