Epic Fail- Turbo Edition
the should add the dude who welded his pinion and ring gear together to tighten them up!
Then they could invite the 'Direct Exhaust Injection' guy to the party to tune 'em up after they're done welding...
(for those unfamiliar with the genius behind "DEI- patent pending")
A guy called me on time when he put exhaust on a car and couldn't get the car to start when he was finished. He wanted me to come diagnose what could be wrong with the car. When I got there, the car wouldn't turn over at all. I thought it was strange and the car battery tested good, but wouldn't turn over and the mechanic(and I use that term very loosely) had already put a starter on thinking the starter had gone bad. I got him to explain his exhaust installation and this guy arc weld the exhaust on the car and hung the ground cable in the crankshaft pulley. Needless to say when you weld the crank to the bearings and the bearings to the block, they don't turn over very well when you are done. :rolleyes: :rolleyes: :rolleyes:
Ok...Fine, but did his exhaust design get rid of his 'Drone' at 2000 RPM?;)
