EricS,
It sounds like your problem has been diagnosed per Turbofbricter, u just need to remove a valve spring and look at your exh valve boss and see if it has been cut. Im hoping this is my cars problem. I have so much smoke that I wont drive it at this point. I also have the mysterious starter oil leak with no known wetness starting point. Might as well be some tiny hole in block around the starter!!! I think its possible that the rear main can leak , and the oil blows or slings toward the starter....may never know. Been doing this too long for such madness. Do u have a wet breather after hard runs? That would indicate tired ring sealing and would help blow out oil pan gasket. U have to be careful not to overtighten the blue gasket, but i cant see why your cork is also leaking. Is your pcv working well? if not , pressure in crankcase will be too hi all the time, pushing oil out in many places. Good luck.
