TexasT
Texas, Where are you from
- Sep 10, 2002
You can "adjust" a stock fpr but you have to be carefull because once you "crush" it you cant go back down, so I try to "sneak" up on the base fp I am looking for. A socket and a vice to push the top down has always worked for me. Yeah, I'm cheap.
The other stuff has already been mentioned. Get a maf translator and newer style maf or you will be chasing your tail. Or see if your reman unit gives a full 255 when going wfo when you get a chance. Probably won't.
Those old injectors are probably junk. way better options. Plenty of used 42lbers with a chip for cheap. Another place you are just wasting your time. I know it costs so I've bought used on these things. I did give up and bought the translator new when one of the vendors was having a sale. I was never quick enough when a used one came up. Plenty of used maf out there. Wrecking yard is full of em for cheap. I usually pick up four or five when I make the crawl.
The O2 should be moving up and down, except when you go WFO. This is where the cross counts are important. The count is each time the measured O2 crosses past 450. when you go wfo, Then you do want it to be where mentioned above, 720(kinda on edge) to 800 or so(lean is mean but also much easier to get into detonation if something goes wrong). Your fp should be what ever your boost is plus your base fp psi. If it isn't you have a delivery or fpr problem. This is where a gauge mounted outside the car(taped to the windshield or if you have the budget a gauge mounted out there(never in the interior unless you are using an isolator. You don't want fuel spraying around in there with you in the event of something going wrong)).
Sounds like you are making MAD progress, keep up the good work.
