Tim_D
- Aug 28, 2017
Bummer, Full Throttle is out of stock on Scanmasters until Friday..
SignUp Now!You can set the idle fuel pressure if the engine will run.
It's not adjustable. Get a stock 237 regulator which will set the fuel pressure to approximately 42lbs. with vacuum line off.I did not realize the stock fuel pressure regulator was adjustable?
Have you triple checked the ground wires ? Cam sensor set right? Crank sensor set right? Is your map sensor reading correctly?
O 2s are low 750-850 good
IAC high 10-20 good
BLM high. 128
MAL is 02 out of rang so you have a check engine light
I would guess injectors some leaking and one not working
PS did you notice your vacuum / boost gauge reading ?
