John,
I was not at all offended by anything you, or anyone else posted.
Heck, there was plenty of very informative data, that has me re-thinking different senerios.
When you use HP numbers to come up with a predicted performance, not only do we question is it Brake HP, Net HP etc.,or is Peak HP or Average HP? Enough to keep anybody busy!
When I first played with the calc's for the Chart, I found it interesting that (if I remember correctly?) at 245hp the typical GN would run somewhere in the low to mid 14's. Which most did.
The GN from the factory was rated at 245hp at 4400rpm. I believe they used an(SAE) Net HP figure?
Assuming that? I think net HP, means the HP is measured at the flywheel, on an engine that sports all its belt driven accessories.
I am not sure that it would take in driveline losses thru the trans etc.?
In the old muscle car days of 427's, 454's etc etc. they advertised hp ratings were BHP(at flywheel). I believe it was just the engine with no additional accessories bolted on it?
Getting back to GPM's as measured by the stock MAF or manipulated numbers with extenders etc., I have to ask how accurate or linear are these to make precise calculations on actual hp being produced?
No matter what anyone comes up with, even if correct for peak hp. The actual performance of the car is going to vary significally based on combination of the components.
A car/engine/trans/gear etc has a major impact. Even if both engines peaked at 600hp in the same weight type car. The car that was set up to maintain the higher average hp thru the gears/rpm range would always come out on top.
Using the FAST system, I would figure an average HP by using the capabilities of the Data logging function. Just after the car shifts into 3rd gear, you can lock on to the lowest rpm say 5500 at the bottom of 3rd to say 6200 at the top of third/thru the traps.
The unit log function allows you to average the Injector D.C. for that rpm range(i.e.5500 to 6200rpm).
Lets just say for example that the average d.c. for 83# injectors was 70% than as a Ballpark (.5bsfc) the average hp was 697hp.
The d.c. of the injector may have been 65% at 5500 (647hp) & 75% at 6200 (747hp)
I guess i'm saying what hp number do you use for performance level?? Peak? or average??
I would tend to lean more to the average hp number for actual performance of the car.
I know it gets confusing for us trying to pin down actual power just by saying i'm flowing 360grms per min air, or #'s per hr of fuel etc. It almost never calc's to a finite, to many other variables.
In closing my personal opinion of the engineering fudge factor is the so called VE of the engine.
The rule of thumb is the engine is normally most efficient at its torque peak. I will agree with that!, but the engine sure does burn alot more fuel at its hp peak!! even though the VE is lower.
Bottom line again the more fuel you can burn the more power you can make, just add the right amount of air or visa-versa!
Food for thought, we have TR's out there that run 10.5 to 1 A/F, 11 to 1 A/F, 12 to 1 A/F and run the same e.t's & mph. Whats up with that?? I would bet that the BSFC varys quite a bit between these cars.
Thanks for reading my ramblings, getting late, got to hit the hay,3:30am wake-up to go to work
Joe
