extender chip help
mike86ttype
LOW ALKY!!! AGAIN?
I just got an extender chip from a guy on the forum. i put it in my computer and it makes my car smoke, not like its running rich, and is makes my car want to stall. it is made for a bigger cam and i have the factory cam. could that be the problem. i also have the translator. do i have to change any switches in there and do i have to hook up the wire that came with the chip. thanks for ur help
Extender chip for bluetops, Revision F.
Part number BSC54B0F
B
S=Stock data stream
C=Bluetop
5=98 octance, WOT spark (23/21)
4= Wastegate % 85/80 about 16psi with stock wastegate
B= 800rpm idle / 6000 rpm rev limit, 200-208 cam
0= no anti-theft
F= Revision Fll
The DIP switches on the translator need to be set correctly for the extender chip.
1=On
2=On
3=Off
4=Off
If #3 is set to On it will not run correctly with the extender.
Let me know if you still have problems.
Mike
Do you have bluetops? What version translator do you have? that chip requires 6.0 or newer
Mike
that was it. it idles a little low. do i have to adjust the iac and tps again with the new chip
It should idle slightly higher than stock. You shouldn't need to adjust the IAC or TPS if they were OK before. What is it idling at and what are you using to measure it?
Did you clear the computer after resetting the dip switches.
Mike
