F.S AEM Low Impedence Injector Driver,Plug & Play Harness, 120lb Injectors
xrcuta
F.S. AEM Low impedence injector driver, Plug and Play harness and 6 x 120lb Injectors
CONDITION: Like New. Been on the car for roughly 2500 k's
$480 + $38 Freight
Good for those that require larger injectors than what is currently offered in the high impedence injectors.
The driver is supplied with 120lb injectors, a plug and play harness which makes the install easy and not requiring to splice or cut any wires.
Injector Info:
Weight: 84.00GM
Brands: Racetronix
Manufacturers : Standard Motor Products
Stock: Yes
Categories: Fuel Injectors - Low Impedance
Retail P/N: INJL120
Static Flow lb/hr (n-Heptane): 111.1
Static Flow cc/min: 1225
Static Flow Tolerance +/-%: 4%
Dynamic Flow (mg/pulse): 25.20
Dynamic Flow Tolerance +/-%: 4%
Coil Resistance Ohms: 2.2
Spray Pattern: 3-Prong Cone
Connector Type: Minitimer
O-ring Type: Viton
E85 Compatible: Yes
Methanol Compatible: Yes
Weight (non-shipping): .20 lbs
Injector driver info:
Includes 10 independent injector drive channels for any engine up to V10
Complete wiring system included
Operating Voltage: 8-18 volts, negative ground
RPM Capability: Unlimited
Injector Triggers: 10
Trigger Waveform: Output is activated when input trigger is grounded
Trigger Impedance: 220 Ohm input impedance, pulled to 12V (60 mA draw)
Injector Outputs: 10
Output Current High: 4.15A Peak, Typical
Output Current Low: 1.15A Sustain, Typical
Peak Current Timeout: 5mS
Size: 5.5"L x 4.6"W x 1.4"H
Weight: 2.7 Lbs
Over Temperature Shutdown: 115C (Nominal)
PICTURES:
