Guys,
I'm continuing to clean out my garage and have some more stuff to get rid of...
1) Set of used rear lowering springs - Suspension Techniques brand, 1" lowering, ~13.75" Free height w/ 0.558" wire diameter. Not sure of the rate, seems similar to the 1901R Hotchkis I just installed. Rear sits at 25.75" from ground to top of fender lip at the middle. I'm including a pair of factory rubber isolation pads that are still in good shape too. $85 shipped.
2) One brand new TA Performance Billet Roller TC, Part number TA1523A.004. This set is for the stock type cam snout, is .004" oversize for line-bored blocks. It has the 9-way crank rear, and an upper billet gear. It was used only for mock-up purposes only (I need more gear size), and has the install instructions. This is a nice part.. Normally $145, I want $125 shipped.
3) One used Translator Plus - Version 6.21. I recently decided to upgrade to the newer translator to see if it would fix a tip-in stumble (turned out to be my TPS, LOL). This is the Translator Plus version, and includes an adapter harness for 85mm MAFs, and the user manual. Although the label is missing, it is Version 6.21 (6.25 is the current). $100 shipped.
4) Thrasher Chip for BlueTops (36 lbers), 92 Octane, No Stutter, No alky, and has anti-Theft. I have the start procedure instructions for the anti-theft. $35 shipped
5) Turbo Tweak Chip for BlueTops (36 lbers), 92 Octane, 16 psi boost, no alky, 18.5/17.5 spark adv older version of chip, I have the program parameters sheet available. $35 shipped
6) Turbo Tweak Chip for 60 lb inj, 92 Octane, alky, 23-25 psi boost, 23/21 spark adv, Ver 5.5 chip Runs great!! $45 shipped
Best to PM me for info or offers, shipping is included in the lower 48 States, others contact me and we'll work something out. Thanks for looking...
John A, Turbohh
John A, Turbohh
