salvageV6
Daily Driver
- May 25, 2001
How did you test the valve?
Did you test it under load while driving?
It's probably the EGR operation, and you can have low CO %'s with these cars.
I never noticed much help from a Cat. with NOX emissions, EGR is a big factor there as mentioned by others previously.
I've passed with the usual cracked header with NOX numbers much lower than you are experiencing it could be hurting but I doubt it's your main problem.
