I purchased a used classic ecu years ago and finally have my car to the starting stage. The engine is a 355 chevy lt1 based engine with 65lb injectors that is turbocharged. The engine starts fine but runs lousy. Unless you are constantly cycling the throttle it will not stay running and the exhaust smell will drive you out of the garage. I was hoping someone would have a setup close to mine so I can see what the fuel file should look like for a fast classic bank to bank.
Thanks.
Ed
Thanks.
Ed
