DOHC Vobra
- Mar 11, 2002
Hey Craig!
I'm considering upgrading my B2B ECU to SEFI, but have a couple of questions... First, a little background. I've installed the FAST on my 97 Mustang Cobra (4.6L DOHC, EDIS), and successfully have the B2B stuff working. I created a "harness adapter" which allows me to simply plug the FAST into my stock ECU connector, so I'm not using a FAST supplied harness. Now, I'd like upgrade to SEFI... does the FAST require a specific Cam trigger, or can I use it with the stock Ford Cam trigger on my car??? If so, I'm assuming that if I connect C3 (CAM+) and D3 (CAM RTN) that I'll have everything that I need for sequential operation... does this sound correct to you?? (or are there additional pins that need to be connected for SEFI operation???)
Thanks for all of your help...you are definitely the FAST god!!!
Justin
'97 Vobra Coupe
http://www.guieectuner.com
Justin
'97 Vobra Coupe
