Fastest Pump Gas / Alky Car...?
Was answering some one ? From the other day .
Pat you would go 10.70 with your time!!!!
You guys really amaze me!!!
JD
Got the new MT 275/60 radial pros in today. Going to put on the new shoes and head to the track tomorrow for some Alky passes.
Got some pretty good times Wed night.
1st pass - 60' = 1.43 / 1320' = 9.61@141, hit the rev limiter shifting 2 to 3
2nd pass - 60' = 1.37 / 1320' = 9.49@144, short shifted the 2 to 3 lol, but still picked up 30mph in the last 1/8th.
The alky was working good, and I really like the MT radial pros. I went from a 325/50 MT drag radial to the new 275/60 and was apprehensive about the smaller size. The car just started working really well on the 60'.
I do think this thing has some 146 mph in it, but I need a shift light. I just can't seem to keep looking down at my tach and trying to watch the dang track. I need to get the vids from my friend and post them.
Awesome run's!!!!
Shift lite should be an easy install!!!
Keep us posted!
JD
Just on the phone and someone just moved up the list, and he's still running today. Something like 9.8 this, 136 that, blah, blah, blah. : )
He's made three 9 sec runs today.
got the text as well
looks like 9.815@137.68 so far!!
was a good day at atco today, buick vs ford and mustang
didnt change anything since it ran BOPalooza event the saturday just after sandy hit
first pass time shots
only a 1.523 , 6.38 @ 110.2 and 9.960 @ 136.81
second pass time shots
1.529 6.38 @ 110.04 and 9.974 @ 136.79
3rd time shots..added 2 psi to launch boost (now at 9.5 psi and 4000 rpm 2- step)
1.464 6.229 @ 110.26 and 9.876 @ 136.91
4th time shot --wasnt going to go but what the hey, added 1 psi to 1st stage (now 25.5psi ) and set 2-step to 4100 rpm
1.448, 6.251 @ 110.73 and 9.827 @ 136.79
called murph and he went through the list and told me i was in 3rd on the list as jc had a 9.82 with a 5.... so close :(
so back out again for elims so not pushing it anymore dialed 10.0 and hit a -007 so i stayed on it and went
1.454, 6.29 @ 110.33 and 9.877 @ 136.80
im out on a red so have to wait so either go home or wait to run time trials for a last chance at the #2 spot ...
so i decide to hang and up the launch 1psi (now 10.5psi) and move 2-step to 4200
not good .... blew tires off and 1.863 6.752 @110.5 and 10.320 @ 137.23
mph looks promising so i hot lap back into the lanes
and not wanting another tire spin run i drop the launch back down 1psi (9.5 psi) and take 2-step back to 4100
1.463 4.055 6.259 @ 110.97 8.178 9.815 @ 137.68
boost was at 26.5 at top and timing at 18.5deg
93 (mix of quik chek and valero pump gas )
meth dual nozzle alkycontrol
weight at 3520
325/50 mt radials (28") at 18psi
th400 ptc 9.5 19 blade , 3.42 stock gears
air temp was in the low 40s
109 ...stock main caps and bolts holding the crank in
fast seq classic
10.6 af targeted
Way to go dude.. awesome to keep messing with the setup and figure out what it particularly likes. What kind of boost controller are you using? The old MSBC? Or did you change to something else?
List of Fastest Pump Gas/Alky Regals with a 109 block
1. snyderjw1.......................9.623@143.28
2. pacecarta.......................9.815 @@137.68
3.JC'sGN.............................9.82@137
4. 1985GN............................9.91@137
5. Grumpy............................9.94@138
6. jdsgnx...............................9.99@134.46
7. RICHIE HIGH PSI.........10.05@133
8. GNDriven.......................10.06@139.3
9. TURBO 6........................10.12@132
10. murphster.....................10.19@129
11. J-B Racing....................10.22@136
12. SloGN...........................10.24@130 -------------------------10.19 @129.8 reynolds ga
13. cutt...............................10.30@128
14. HiTech6..........................10.365@128.51
15. Quik Six.....................10.373 @ 131.8
16. Super6..........................10.41@128
17. insane6........................10.44@112
18. turbo6randy.................10.46@131
19. Slow91z........................10.48@128
List of Fastest Pump Gas/Alky Regals with a stage block
1. Robert Wilson.................9.221@146.61
msbc-1 with co2 now setup in wastegate mode using a 2psi hobbs off ebay (no more spiking) and using a 4.5psi spring in pw 46 gate on an old atr 3"pipe
still running full dual closed exhaust through the mufflers and on a .63 exhaust housing
What does the Hobbs switch do exactly? Where is it wired?
