I have a POSSIBLE buyer, but nothing serious as of yet. So i figured i'd ask around just incase, to get a head start. The car has just gotten to fast for me right now, and i want to get back into my 4 wheeler racing.
Brief Details:
87 Turbo-T(chrome trim)
58k on the clock
T-Tops
Black Exterior-condition 7 of 10
Grey Interior-condition 8 of 10
All Original
Performance:
234ci
23'000 mile 109 block
.30 over Diamond Pistons
RJC Girdle
K-1 H-Beam Rods(floating)
Cat Crank(stock stroke)
Center Billet Caps
King Bearings
Hi-Volume oil pump
RJC Crank Scraper
JW(the wheel) flexplate
BHJ(internal) balancer
Port Matched Stock Intake
218/218 Hyd Roller Cam From DLS
918 Beehive Valve Springs
Comp 853 Lifters
Chrome-Moly Push Rods
Champion Ported GN1 Alum heads(porting done by Nick Micale)
70mm Throttle Body and Matching PTE Plenum
F.A.S.T XFI with 83lb injectors(including laptop)--from Cal Hartline-he helped me tune it
Full RJC Alum Pulley Set
PTE Front Mount I/C(new design)
TA Stainless Headers
PTE 70GTQ Turbo(3 bolt)
HRparts poly motor mounts
RJC Zinc plated deep sump oil pan
Full Billet 200r4 w/ Transbrake
Pats Perf. 10.5 L/U 3800 Rated stall converter
Denny's Nitrous Ready Driveshaft(all 1350 series w/ chrome moly trans yoke)
Moser 30 Spline Axles
TRUE Detroit Locker(the good one)
TA Rear Girdle
3.23 Gears
FULL HRparts Rear Suspension with ajustable sway bar and control arms
Competition Engeneering Front and Rear ajustable shocks
S&W 8Pt Roll Bar
Aeromotive A1000 Fuel Pump
Alum 15 Gal Fuel Cell in trunk with sender(gas gauge works)
Unpainted Fiberglass Front and Rear bumpers/bumper fillers just went on
Alum Bumper brackets
Has Dual Electric fans
Brand new Lightweight Braille racing battery setup(15.4lbs!)
3.5in Internal Gate Downpipe w/test pipe
3.5in Electric Cutout
B&M Quicksilver Shifter
ATR Dual Stainless 2.5 Exhaust(with Stainless Dynomax Mufflers)
thats all I can think of right now, i know theres more
Car Has WORKING A/C and HEAT
THE TRANNY BROKE AT THE LAST TRACK OUTING, I BELIEVE IT BROKE THE BILLET DRUM OR BILLET INPUT SHAFT. CAR CAN BE SOLD AS IS OR I CAN FIX IT BEFORE SALE.
Engine has maybe 1000 miles on build and maybe 35 passes or so(10 passes actually running the car)I race 99% 1/8th mile, been to 1/4 mile once....One of the first passes on it(street tune)10.54@128. Went a 6.7@101 in the 1/8th that pass. That was last July, car has since gone 6.23@109.7 with more to go! thats a solid 9.7-9.8@138 or so. Trans shifts awsome, rock solid, no glidng shifts or anything. Rearend has maybe 250 miles on it. Tranny is fresh...except for broken part. Since this is a Feeler thread I don't want to post a price yet, I just need to se if there's any interest.
thanks,
Cody
Brief Details:
58k on the clock
T-Tops
All Original
Performance:
234ci
RJC Girdle
Center Billet Caps
King Bearings
Hi-Volume oil pump
RJC Crank Scraper
Comp 853 Lifters
TA Rear Girdle
3.23 Gears
S&W 8Pt Roll Bar
thanks,
Cody
