I just spent $27 for an oil pan gasket. Of course I have some reservations. Has any one ever used a felpro perma-dry oil pan gasket and did you have good luck with the product. This gasket is rigid, with a neoprene type laminate over the gasket and has raised material to enhance sealing. It is also very thin. So tell me what you think?
I really like the gasket, last 2 times I have dropped the pan, it sealed up nicely, don't overtighten though, use a 1/4 in drive ratchet, when i use a 3/8 I tend to overtighten, if you do it will leak, 27 bucks though where did you buy it at, good luck
