Finally a 11 sec time slip
gbsean
still alot left in the car as this was the 1st WOT blast on new motor with no knock issues 22# boost w/22* timing in 1st/2nd 20*/3rd AFR at 10.0 and alky turned off...there is alot left in my combination...add timing/boost/alky/leanout better launch
60' 1.788
330 4.903
1/8 7.539
MPH 92.58
1000 9.832
1/4 11.769
MPH 116.51
Dan Smith Motor Build girdled
w/ported intake and exhaust
forged crank and pistons .030 over
REV XR2 210/215 Buick hyd roller cam
1:55 Harland Sharp Roller Rockers
Comp Hyd Roller Lifters
8.225 pushrod for hyd roller cam
BEEHIVE" SPRING FOR BUICK ROLLER CAMS
Full Ball Bearing version of GT6776
HD WG actuator
Steve Monroe Throttle Body
RJC Power Plate
60lb injectors
Terry Houston Down Pipe
ATR 3" cross over
Electric cut out
ATR 2.5" SS Exhauts W/ Pitt Bull Mufflers
Precision 9" 5 disc 3000 stall convertor
MAFT PRO
Tuner Pro Chip for MAFT Pro
Power Logger
Scan Master w/update Chip
UMI uppers and lowers
PST front and rear sway bars
Eibach Springs front
Moog stock springs rear..for racing Eibachs for street
Stock Rear
200R4 Trans with all the goodies
Congratulations, Sean, great parts list. Great time-slip too.
Congrats!!! Ain't nothin like running a new best. That combo should net you in a 10 sec. timeslip w/ a good 60'. Glad you sorted out the problems you had previously.
