Im just asking how you can read my thread on how I set up a bypass system on my TR, and now its your idea. I mentioned on here, doing this to my GN a year and a half ago.
Anyway, I used a greddy BOV as a bypass before. It didnt work right. I had to tear it apart and change the spring so I could get it into a range where I could adjust it. Out of the box, they are too stiff and will only open under a huge pressure spike. Also, you need to know that different bypass valves will have a different stroke, and therefore, diferent flow capacities. The 108's to 110's and I think 112's, have a brass plated diaphragm (vs plastic) which is alot stronger, but the stroke is much less, like 3 or 4mm. This makes them very responsive in a road racing application where you're quickly on and off the throttle, but lacking in the air volume dept. The 103 opens like 10mm, so its enough to completely bypass air around the turbo during cruise, and enough to dump a huge volume of air. But, they arent rated for big boost. Ive planned on setting up a dual 103 system so the psi wont damage the diaphragm.
Something I didnt expect was that the engine is alot quieter on the freeway. Its extremely smooth. Probably has something to do with bypassing the turbo. It spools really well and the vacuum to boost transition is alot smoother.
By the way, by the looks of it, my mileage looks to have improved.
Also, DSM's didnt come from the factory with BOV's. I dont know of any factory car that did. It came with a bypass valve. You say you have a BOV from the factory, but you cant vent to the atmosphere or itll run like ****.
You're contradicting yourself. A BOV DOES vent to the atmosphere. Your car came with a bypass valve. Venting to the atmosphere dumps metered air into the atmosphere and causes a huge rich spike, which is why it doesnt run right. I bypass valve only circulates metered air, so there is never a problem with A/F fluctuations.
Maybe you misunderstood something. Maybe you think I made a BOV on my car. I made a BYPASS valve, which is routed back into the intake, after the MAF.
