Well I haven't done to much this last weekend but both uppers are now done and I've started on the lowers. Here's a pic of my improvised welding stand.
Not great but it does the job at least.:biggrin:
If you look at the red thing in the center of the arm it's the brace that keeps you from crushing the control arm when you bolt the sway bar to it. I welded it in the center so I could make sure it wouldn't move when I put everything back together. Leave the ends unwelded so if you have to tweek it slightly you can get it to line up so the bolts will go in. Three of the holes lined up but the fourth was off just enough that I had to tweek one side. The last pic is of the brace for the bushing again. The lowers are narrower than the uppers so it makes it harder to weld them in. I also attached the inside top to it this time since it has better support than the uppers.
