First pull with alky
87we410877
I just logged a pull down the highway with the alky kit for the first time. I have the dual nozzle kit and just wanted to see what was going on. Im at 18 lbs of boost, 93 octane, and using fast bank to bank. My A/F the whole pull was 9.19 and the 02 correction was steady at -10.2. This seems way too low for the air fuel. EXC rtd was 0.00 the entire time. What should i adjust?
Set the commanded A/F in the upper boost ranges to around 10.5-11.0 to start with. Keep reducing VE in the affected areas until you can get the A/F into the 10.5-11.0 area. Make sure you datalog the runs so you can see where to reduce VE in the VE table.
+1
