SignUp Now!What source? 300.00 i can do..ThanksGunzandgearz where do you come up with $1200 for roller and only $150 for flat tappet. I got a custom roller cam for just over $300 however i had the lifters and push rods already.
Almost any vendor.What source? 300.00 i can do..ThanksGunzandgearz where do you come up with $1200 for roller and only $150 for flat tappet. I got a custom roller cam for just over $300 however i had the lifters and push rods already.
I come up with it because when you buy a roller cam you are also going to have to buy new roller lifters new pushrods a lot stiffer Springs and roller rockers add that up and see what you come up with then go look at the cost for a set of hydraulic lifters and hydraulic cam picture will start becoming clear but since you already had the lifters and stuff most people don't have that so that's where the huge difference in cost isGunzandgearz where do you come up with $1200 for roller and only $150 for flat tappet. I got a custom roller cam for just over $300 however i had the lifters and push rods already.
Amen...Anyone know the guy or gal that broke all the flat tappets in at the factory?
I think I need to buy him/her a beer.![]()
I am not sending and engine out of here with a flat tappet that I don't breakin personally.Steve is good and can break the cam in before shipping but what happens if it's not broken in and you drop it in and have a problem with the flat tappet cam. You will pay for the re and re again, most builders rotate the engine to make sure everything is rotating smoothly however that is not holding the throttle for 15 to 20 minutes for breaking in the cam. There is an old saying you pay for what you get, cut corners and it generally
