WarWagon
Caustic Cacophony
- Mar 10, 2007
I'm going to switch blocks in my buick. My current block has a dead #2 cylinder with 0psi compression I suspect rings. I found a clean lower mileage '85 ttype block that I'm going to mod like my '83 block to work with my setup. I'm still using a stock '87 GN camshaft. I'd like to know what I can run If i want more cam. otherwise the Stocker was doing fine in my setup just dying at top. I'm running a t3/t4 with a around a 60 mm inducer and have 3in DP with outout and a external wastegate. aftermarket headers semi ATR style. And blow though induction. Smokey Yunick Weiand intake, FMIC, 800cfm Demon, msd fuel pump, mallory 4309 boost refenced FPR. 100 shot wet NX kit, Hei Ignition, 3.42 gears and a 3speed. I want and need a 4spd just can't find one yet.
