fluid talk
jlat
hello people's: I'm talking changing of the trans. fluid here. I co-worker was just telling me he takes his work truck to like a Jiffy Lube and they hook up at the trans lines at the rad.to do the job. It kinda like a transfusion with out with the old and in with the new. He also says this process takes all the old fluid out even the fluid in the torque converter. I don't think that's true?
What does TB world think?
IBBY
It's pretty well true, nothing is 100% but that machine is about as close as we could ever get in the car.
Only problem is if you think you've had junk run through your filter this way obviously won't change out your filter so that could be not good.
And it isn't cheap.
