So after months of not touching my car I took today of work with two goals.
Replace front upper control arms and get fresh long block installed.
Upon tightening the converter to the flywheel I noticed one converter boss was touching the flywheel and the other two had like 1/4 inch gap.
Rotate the converter and the touching location remained in the same spot on the flywheel and did not follow the converter boss.....
So WTF. It is a stock flywheel. How should I verify it is the flywheel?
Thanks. I have a feeling I'm going to need another day off to remove the engine again.
Give me some ideas guys.
