My wifes 04 expedition was idiling in park and stumbled then shut off.I checked the normal things like relays,even pulled fuse panel out.All relays looked good and clicked when key was turned on.Put a new pump in and still will not start.It will start with ether.What else will cut the fuel pump power?The reset button wasnt tripped.Is there anyway to bypass the relay on the back of fuse panel?There is a black box above the spare tire that has 2wires going in,both are hot with the key on.Thanks.......
