Tampa T-Type
- Jul 17, 2005
1985 Buick T-Type
1987 ECU
Spearco Intercooler Part # 2-135
Turbo Turbonetics, Cheetah .63
Razor Alkyl running methanol
Adj Wastegate
GReddy Profec B2 Boost Controller
Kenny Bell Headers
Kenny Bell Air and breather filters
Fuel pump 340
Hot wire kit
Chip Thrasher 93
K&B dual stage headers with down pipe
3” High Flow no-cat converter
2 ½ dual mandrel exhaust
MSD 50 Lb injectors
Lt-1 Maf
Translator
Bosch Adj fuel pressure regulator
2004R Shift kit rebuilt with all new performance parts
2800 Torque Converter
AVC Motor Sports GNX cluster dash kit analog
30 Lb boost gauge
Oil pressure
Temp Gauge
New cam “cams 231t 0.519”
New crankshaft 0.646
Valve springs
V-8 Radiator
Rod and main bearings
Oil pressure booster plate
Throttle enhancer
Turbo ram air not installed
New Egr
New O2
New Plugs
New Wires
New Vacuum Lines
When I purchased a 1985 T-Type, it had many new suspension parts and all service records. It was set for 9 Lb’s of boost and has an adjustable wastage.
Over time I have added the following items and am presently up to 23 Lb’s of boost.
I just purchased a Data-link and will install it soon but a problem I am having is breakdown on full throttle, plugs and wires are new. This is the final piece of the puzzle and I hope the Data scan will find out what is wrong.
This car is street driven!
Is there anything else I can do to bring this up to an 87-performance level? I love this car its gold and is a sleeper.
1987 ECU
Adj Wastegate
Kenny Bell Headers
Fuel pump 340
Hot wire kit
Chip Thrasher 93
MSD 50 Lb injectors
Lt-1 Maf
Translator
30 Lb boost gauge
Oil pressure
Temp Gauge
Valve springs
V-8 Radiator
Throttle enhancer
New Egr
New O2
New Plugs
New Wires
New Vacuum Lines
