conn84gn
- Jul 13, 2005
Motor was rebulit about 8000 miles ago ran fine till now
keeps fouling #3 plug and runs poorly above idle studders
All the other plugs are nice and clean
Compresson in all cylnders 145PSI
New plugs,wires, coil tested good No smoke no water
Motor has a slight ticking noise
Changed injectors from 37's to 009's and changed the chip to match
Samething
No codes
Did I loose a cam? bad spring? lifter?
Samething
No codes
