Tim Cucci
- May 24, 2001
I have the engine out of the car to install heads,timing chain,and weld headers. I have already installed the heads and intake while waiting on the new timing chain and rear seal from Jack
Cotton. I dropped the pan and found timing gear teeth and non-magnetic metal. I pulled the # 2 main cap and looked at the thrust bearing and found the sides of the bearing scarred and worn. I am now thinking of replacing rod and main bearings from the bottom end without pulling the heads and intake back off and wasting the gaskets. Any suggestions on this method would be very helpful. Which manufacturers bearings and do they need to be specific for VIN 7 eng.? Things were going great until this happened. Anyone know what caused this problem? The crank has over .030" end play also. Engine has 60,000 miles on it.
Tim
Tim
