ttypewhite
- Oct 1, 2001
holy old thread dug up from the past..
i notched my frame , used 3/16 plate , rolled the lips , kept inner wheelhouses with a little massage at the ends
15x 10 weld aluma stars 5BS with a 3/8 spacer .. stock 8.5 rear housing (could have notched further but the wheelhouse would then be the limiter)
running 325/50 MT drag radials
hr bar stops all lean over . wolfe double adjustable CM upper and lower arms so axle is centered and no possibility of any side to side movement (hr braced at lowers) , wolfe adjustable spring perches on axle allow me to dial in close to tire (using 12-150 coil over springs ) . Qa1 adjustables set pretty firm so no worry of squat causing rub on hard launches... and it hooks
That looks sooooooooooooo good. Would you happen to have any pics underneath the car to show the work done? I would like to see how much room is left around that tire and the frame/ inner wheel wells) Since you have done this, do you know if the qtr panel buckles when launching the car? Again, that looks great!!!
