You answered the question. If your ride height goes up on an unequal legnth control arms set up your tires will go to negitive camber, not positive. The shorter upper travels at a more extreme angle and the longer lower doesn't travel in the same arc so the tire goes negitive. That's why the spindle change going to caprice spindles gives you a better camber curve. It changes the arc of the control arms to a more simular one.
