I have what he is talking about. Notice there is no place for a stock style spring to sit. The coilover also does not need the T-bar to bolt up to the a-arm.
You can easily use the afco's on a stock or tubular replacment that works with stock shocks and springs. All you have to do is buy the t-bar, most come with them. But, before you buy, set the car on the ground at the ride height and measure where the stock shock would be. Everywhere you read it says g-bodys use a 4" shock. On mine a 4" shock was sitting on the bump stops at ride height. I had to buy 3" travel to work right. TRZ says this is pretty common. If you measure and call TRZ they will sell you the right length.
For springs, you can run stock or coilovers. With coilovers you have two choices. You can buy the QA1 beehive springs, they they only have a few spring rates. Or you can buy the TRZ spring adapters that use a 2 1/2" coilover spring that gives you lots of spring rate choices, but you have to cut the factory spring seat out inside the frame.
