scot w.
GNSperformance.com
- Feb 19, 2005
I have seen the passenger side tire only rub on more than one car and have seen several people post about this problem. Well today while getting ready to do the front brake install I wanted to get sort of a reference as to where the wheel mating surfaces were on the stock set up before doing the install, that way once I was done I could due this test again and it will tell me exactly how much the BAER track-4/SS4 system pushed my wheels outward. Once I seen the outcome of these measurements I felt this information needed to be posted for the members..
I done a simple test By using a plum bob tapped to the outer fender (centered to the hub) to see how well the wheel mating surfaces were aligned to the outer wheel well trim. To make sure the plum bob was always in the same spot on all corners I measured the rears off the tail light housings over to the string and on the front I measured from the door/fender seam over to the string and here is what I found...
The front LEFT: (Measured at 7-1/16")
The front RIGHT: (Measured at 6-1/2") The measurement is LESS because it is More towards the outside by 1/2" than on the LEFT side.. This explains the passenger tire rub on MANY cars!! We are going to try to see if we can find out the reason why this is like this on so many cars, then we will try a few things to correct it....
Now we can go onto the rear of the car and see what we have..
Now onto the REAR measurements:
Rear left: Measured at 7-1/4" (bad angle, hard to due with only two hands)
RT rear: Measured at 7-1/4" (Better angle this time LOL)
And here is what the set up looks like and how I measured it for each side:
Front LEFT:
Rear:
Front LEFT:
	Rear:
