scot w.
GNSperformance.com
- Feb 19, 2005
Just weld vertical supports/locators to the body & frame after centering it... problem solved.![]()
SignUp Now!Just weld vertical supports/locators to the body & frame after centering it... problem solved.![]()
I happen to disagree, I have 255/35-18 in FRONT and 285/40-18 in REAR With NO frame notch and just a fender lip roll, I am lowered 2" and completely off the stock suspension and only had a slight Scuff on my outside passenger tire when I had two people in my car! It wasn't tearing tires up, It wasn't gauging the tire, and it never ruined a single tire, it was only a scuff and so slight I bet you couldn't even see where it was done!! So with my 10" wide wheels in back and the 9.5" wide wheels up front THEY WOULD FIT "PERFECTLY" if the body/geometry issue from the factory wasn't there!!
Now then, Move onto the issue with the brakes moving the wheel outward all I have to do is send my wheels back to CCW with the measurements in my test and they will take care of that small brake issue real fast! Either by changing out a hoop on each tire or what ever John wishes to do.The "TRICK" begins with a quality 3-piece wheel and a wheel manufacture who knows these Buicks like the back of his hand and knows what it takes to make the wide ones fit. I was lucky to have been introduced to John @ CCW..
Your outcome depends mostly on your combination/set up...there are MANY way's out there to accomplish a handling car with the many suspension company's out there. There is just way too many variables that come into play here....(example) Back spacing, Wheel size, Tire size, Brakes, OEM/Drop-spindles?, 1"or 2" drop-springs?, reg or coil over-shocks?, Etc, Etc.
Some people may want to get the best bang for the buck in instant better handling over stock and to me a nice set of wheels and tires seems to make the biggest difference for the buck. Or they may not have to funds for all the other stuff first. Then it's sway bars, Then bracing, than if that still isn't good enough the suspension would be next....And even after the suspension upgrades like brakes, a-arms,etc,etc you still shouldn't have to buy two different sets of front tires because of this!
Yeah in a perfect world and endless pockets right from the start it would be BEST to do Everything all at once but not many can do that so people are forced to due things in steps just like me,I'm no exception. It may look at times like I have endless pockets but the reality is "Tax Returns" I only do one large thing to this car per year and that's it...Wheels & tires one year, The next was interior, the next was suspension and now this year it's brakes finally after 4 yrs this car is getting to where I envisioned it. so it can be done like this you just have to do it right the first time around and save yourself a bunch of hassle & time....
I don't want this thread to get off course, so let's please keep it on track so it can be used as it was intended for.
I will report back with more info when it's available.
Scot W.
Not True! For the record they are not Taking Them back! They are just going to change a Hoop or do what they have to "IF" they need it.. Who knows, I may get this issue squared away good enough where the wheels will be fine... Keep in mind NOTHING was done to my inner wheel wells and I will do everything in my power to keep the wheels just like they are!!Glad to hear your wheel place will take your wheels back. They will have to be changed.Enjoy!
That's the plan Charlie, We have been looking at it today and even came up with a cool little remedy to keep the body in place once you got it where it needs to be. If this ends up working out I will post pic's and a detailed write up on what needs to be done, BUT testing needs to be done first to determine if this worked or not...
Thanks for chiming in, your thoughts are always welcome!
Scot W.
I have several choices here:
1) Nothing may have to be changed at all, too early to speculate!
My money is on this. As long as the hub dimensions are constant with the stock rotors, the only thing you are going to have to factor in is the hat thickness of the new aftermarket rotor (which is what? 1/4" to 1/2").
Third, Front A-Arm Swaps an/or disk break set-ups, will set your wheel out to the fender a Inch on both side's,an drop the car about an inch in the front. When your tring to fit largest wheel tire you can in the front, These 3 things i mentioned above will Messs with You Bad!!!
Enjoy!
Thanks for posting your thoughts!
I'm not too sure I believe the story about the added room for the downpipe & turbo. Reason is, I have seen friends take a regular regal (not meant for turbo or down pipe) taken and made into a turbo regal Plus Monte Carlo's also have the same issue how do you explain that?
I don't believe that GM was stupid and off this much in their geometry on the front end of these cars.
However, I DO believe like Kevin B. posted it's more likely the body on the frame that has shifted over time OR was set wrong from the beginning at the factory and that is what I will address first to see where that gets me.
Car has never been in any accidents!
You are correct and I am well aware of aftermarket brakes pushing the wheel outwards and can even tell you that BAER say's they push the front out .400 and .300 in the rear.. BUT these measurements taken were using STOCK BRAKES!
Just to let you know this wheel offset was visually noticeable and the first person to notice it on my car was (TurboDave) about two years ago when I had the GTA wheels on And that was with the STOCK A-ARMS too!! So this issue seems to have nothing to do with Any aftermarket parts or Any accidents.
Good post Bozo! (no pun intended, it's just your screen name) LOL
Scot W.[/QUOTE
It's a nasty combination to over come,everything will add up, but it's possiable to over come,I just put my atr rate springs back in the front,did some "GNX" fender clearancing, I have No Rub!...8^) with 255/40/18's in front ,still stock body bushings,no wheel spacers,with 1" drop from the BMR a-arm swap an the inch out to the fender with aerospace brake kit.Now i'm working on the back to even the stance out,added the ebich 1" drop spring back to the back an getting new bilisteins today, (mine are 20+ years old)
i'll have new photo's end the week
Enjoy!!
Sorry about my last post as I just read this and see you of course already know about the lowering with the BMR's!:redface:
What rear springs are you using?
ATR's rate springs,added the 1 inch drop Ebich springs out back again an just waiting for my shocks to get here Monday to put the car back on the ground an see where it stands,should be nice an level, i run a 28 inch tall 295/40/18 Falken Azenis out back,no frame mod,just upper fender lip roll,When i do the frame bushings an even out the front clip, i can add the 1 inch drop ebich spring back in the front
Enjoy!
Bingo! This was going to be our first line of attack. We are going to remove all of the body bolts and try to shift the whole body over a 1/4". This should equal the measurements out from side to side. When your talking only a 1/4" it seems very possible that GM could have set these bodies off a tad or it just shifted that much over time....
Can you link us to the kit you used?
Thanks!
Scot W.
I just used the energy suspension kit that jegs sells for about 150 or so. ... The energy kit comes with the "Gnx" bushing also. After the install, the body will sit about a 1/4-1/2" higher on the frame. This may help rubbing issues also.
