I installed a set of Spohn Front lower control arms, and it lowered the car about 1" causing the front tires to rub when I hit a bump. Is this to be expected with spohn control arms??? I'm running 225/60/15s up front and had no rubbing issues before. Is there a stiffer or longer aftermarket spring out there?? I need to raise the front back up at least a half inch. don't want to run smaller tires the car was raked enough before now I feel like I'm sliding forward when I sit in the seat.
