I just finished my brake system and the front wheels barely turn by hand when the car is on jack stands. I have to give it my all just to get them to turn. Is it because there is too much pressure up front? I have a brand new Kirbans stock replacement brass proportioning valve, all new stainless lines, factory rear drums, and the dual piston Blazer S-10 setup up front with the 11" rotors. I also have a brand new manual brake master cylinder. I bled the entire system one wheel at a time to get all the air out and my brake pedal is extremely firm. When I barely touch the pedal, the rear wheels will lock. They spin freely when I release the pedal. Wish I could say the same for the fronts. Do I need an adjustable prop valve? Or will the front wheels eventually loosen up as the pads wear down. Or is any of this normal for a manual brake setup?
