FS: Fuel Pumps, Injectors, Caspers VSS Buffer
TType85
TurboBuick.Com Supporter!
Have some stuff for sale. The fuel pumps are ones I didn't end up putting in to the car and went with a brushless pump setup. Prices are shipped in the US. Discounts for buying multiple items. Local pickup also in Garden Grove, CA.
1 - Deatschwerks DW300 Pump - rated at 340LPH at 40psi. Pumps were replaced by DW under warranty and only run to test operation. They will come with the wiring connector and fuel sock. - $100ea.
2 - Deatschwerks 420 Pumps - rated at 420LPH at 40psi. Bought new to put in place of the DW340's and only run to test operation. - $125ea.
Racetronix 160# injectors, purchased used from Full Throttle Speed. - $195
Caspers VSS converter - Used, complete with VSS. Used to send correct VSS signal to both the stock ECU and a aftermarket speedometer. - $100
I actually just emailed Casper's because I need the "sender" only. I think my sender is bad because the LED remains a solid on the module instead of blinking while the car is moving. Did you ever get this to work properly? I know this isn't the place to ask this question so forgive me.
The VSS buffer/converter worked perfectly for me. The ECU and the speedometer were getting the correct signals. I do not recall what state the LED was in though.
