TR Custom Parts
Mark Hueffman - Owner
- May 25, 2001
Ready to just leave this thing parked in the garage. According to some logs it looked like my 15 year old pump (around 20K miles or so) was not keeping up. Bought it from Kirban back in 85 and BELIEVE it was a Walbro 307.
Decided since the tank was 23 years old that I would just replace everything, new tank, sending unit, Racetronix Walbro 340 pump, new AC Delco fuel filter. Also put in a new Racetronix hot wire kit to replace the home made one I had. Hoses from sending unit to metal fuel lines was replaced, used submersible fuel line for the connection from the pump to the sending unit. Restriction was removed from the end of the pick up line, not the whole necked down part, just the end. Don't really think that should matter.
Getting 13.5 volts back at the pump at idle. Have the ground installed per Racetronix that goes to the rear bolt of the fuel strap and to the tank. Bare metal section with dielectric grease on the tank lip. Also put another ground from the tank lip to the frame itself. All grounds are to scraped bare metal.
Just assuming that the rubber line at the front of the frame is OK since the ones at the back of the car appeared to be fine but will check them out when I get the car up on the ramps.
Boost dialed in at 22 lbs with alky. Fuel pressure set at 43 lbs vacuum line off. Getting only around 59-60 lbs of pressure at full boost. Verfied with Power logger. Threw another fuel pressure regulator at it to take that out of the equation and same result. When boost comes up I am getting a high BLM spike which means the computer is trying to add fuel. This is what made me to decide to change the pump in the first place and there is absolutely no change. (anyone want to buy my old complete stock tank setup in CT??))
Once the initial BLM spike goes away and and the WB gets the correcton going everything looks fine except the fuel pressure numbers. Getting some minimal knock when I get on it but thinking that might be false knock with the downshift. STILL need to do a from a stop run with this thing but just haven't found the right opportunity.
Going to go thru the VortexBuicks checklist next and go from there. BTW, at a different time I had a 27 lb run and the fuel pressure was up to 65 lbs without any issues.
This is on a 32k mile car and all metal lines look like new at least from the outside. I did notice the bend right before the fuel filter looks like it might have been bent a bit too much but not to where I think it would be a problem.
