Long time in between posts for me...
Bad fuel pump?
Fuel pump is Reds XP, approximately 12 years old.
Car was acting up.
Car would stall while driving when coming to a stop.
Car would stall when making left hand turn.
Car is fine when making right hand turn.
I checked things out and the relay (Hella 40amp) for the hot wire kit was clicking on and off. I replaced the relay and the problem went away, but then the problem came back a few days later.
When I remove the relay and power the pump directly from the factory fuel pump wire, there are no problems.
Volt meter shows the voltage going up / down when the relay is clicking on and off...
Bad fuel pump?
Car was acting up.
