I'm new to this site and have a question. I installed a Walbro 340 fuel pump with a hot wire kit the other day. I have been driving the car for about 2 days after the pump was installed. I noticed fuel leaking from the fuel vapor canister. I'm not going to drive the car until I fix this problem. The car is all stock and this is the only upgrade that I have done so far. The fuel lines have been checked and are hooked up correctly. I have heard the canister has a check valve. If that is it where is it at or is that where the wire plugs in. Also can I purchase one if I need to.
